Undelete - Automatic Program Elevation
Undelete requires elevation (in Win7).
Any way around that?
Or perhaps a prompt to restart Salamander "as Admin", or to open a new instance as Admin, automatically loading Undelete, or something like that?
Not really a big deal, more of an, "oh, yeah, that - again".
Some sort of automation would just make things more convenient.
(Similarly mentioned, but a different request, Automatic launching.)
(Just to note, Net Transport recently, Modified to run Sniffer module as Administrator, so you could open the main program as normal user. In the past, you had to specifically exit NT, then "run as" to enable the Sniffer. Everything has the option to use a small "service", such that the user part of the program need not run "as Admin".)
Re: Undelete - Automatic Program Elevation
Eh... maybe it is.
When all of a sudden, well after the fact, you realize, oh yeah, I've been running with High Integrity all this time!
Would be better if Salamander remained at Medium & only a worker thread to the Undelete plugin ran at High.
And even better yet if that needn't run at High.
(Suppose I should write an RFE so that when Salamander is running High, it identifies itself to you in some way in some fashion.)
Suppose this will be picked up by, Roadmap: Support for Windows Vista/7/8 UAC elevation prompts.
Yes, it will be included.
