Branch View
Branch View
is there any function similar to totalcmd's Branch View? (CTRL+B). It shows all files in current directory and in subdirectories at once in one panel.
Thanks in advance
M.
Thanks in advance
M.
Re: Branch View
I am using Ctrl+F instead without any comfort so I wote for this function too!-=Majkl=- wrote:Hi,
Thanks in advance
M.
Re: Branch View
But you can't use all the functions normally available in panel, can you?ino wrote:I am using Ctrl+F instead without any comfort so I wote for this function too!-=Majkl=- wrote:Hi,
Thanks in advance
M.
Re: Branch View
No, I do not. Can see only list with files...-=Majkl=- wrote: But you can't use all the functions normally available in panel, can you?
That is why I vote for this feature!
Branch View (Total Commander) or Flat View (Dopus), and also in other file managers, is a useful feature for looking at the contents of several sub-directories at the same time. Ctrl+F will do a similar function, but not in a very convenient display. I also vote for this feature to be added to Servant Salamander. I don't see it mentioned on the Roadmap, are we talking about two different features? Branch view is not the same as Tree view.
Hoping for this function also.
I call it the "recurse subfolders" mode. Shows all files that match the filter criteria in the current folder and below. Great for feeding to the multi-rename tool.
Of course, should allow all customary file functions... delete, rename, copy, move, etc, plus all customary views... detail, thumbnails, etc.
Mouse-centric, Registered
Re: Branch View
Here're the results from Germany: 12 Points-=Majkl=- wrote:[...]It shows all files in current directory and in subdirectories at once in one panel
This function is a very good idea!
Kind regards, KNUT
i created a small jpg for this idea. Anyone here wants to put it online? i don't have webspace. Let me know and i'll mail it to you.
I think this feature request is worth to build inside SS. Though i wouldn't want to use it on the C root since windows has lots of dirs and thousands of files.
Not to mention all files inside the program files dir.
