SystemDrive environment variable not set
Forum rules
richb
Post by richb » 15 May 2013, 06:15
Here's an obscure problem for you.
On Windows 8, run Salamander 3.0 beta 2 (x64) as Administrator. Then do Commands - Command Shell. The 'SystemDrive' environment variable is not set.
Same problem on Win 2012 Server. It does not seem to occur on Win 7/2008.
I found this because msbuild fails when SystemDrive is missing. Took me a while to find it!
Brett
Re: SystemDrive environment variable not set
Post by Brett » 15 May 2013, 06:46
Checked on my Windows 8 with the same setup and my SystemDrive variable is present so it is probably not a general problem with Salamander.
Cheers,
Brett
Post by Jan Rysavy » 15 May 2013, 06:53
It is a bug introduced while fixing http://forum.altap.cz/viewtopic.php?f=2&t=6188
We are working on fix, thank you for letting us know...
Post by Jan Rysavy » 17 Jun 2013, 16:03
Problem is fixed, thank you for info.
richb
Post by richb » 12 Jul 2013, 03:34
Yep - SystemDrive is set in beta 3. Thanks.
