Yes for now, sorry.vld wrote:Is this still only for Vista
Offender Plugin
Re: Offender Plugin
Re: Offender Plugin
No worries, your other plugin for TC is working for the time being.
Re: Offender Plugin
Are you aware of TC plugin displaying locked files?vld wrote:No worries, your other plugin for TC is working for the time being.
Re: Offender Plugin
I am now. I haven't really used the plugin before since I could not delete processes. But now that I can, I will need to look at it when I notice a file is locked. Will the locked file be displayed differently?
Re: Offender Plugin
Which one are you using? I use ProcFS and I don't think it can do something like that.
Re: Offender Plugin
Hi tried this plugin now with AS 2.54, on Win Vista 64-bit urtimate - I get an interesting error when I try to examine a locked file...
The process cannot access the file because it is being used by another process
Hugo Ahlenius
Hugo Ahlenius
Re: Offender Plugin
Will this wonderful plugin be updated to Salamander 3.0? Any idea how soon?
