Hello, I am not sure if I should open a new thread for this problem, but starting with 3.0 beta 2 I can not longer connect to MY ftp server that is configured to use SSL.
Salamander completely blocks its window (I cannot cancel or close Salamander) and after a long time I see a dialog with the title "FTP Client" that says:
Unable to establish encrypted connection (SSL).
Error: SSL_connect returned 5: error:00000005:lib(0):func(0):DH lib
Waiting xx seconds to reconnect ...
The FTP server is the Filezilla FTP server running on windows. "Force SSL for user login" is enabled.
The connection to this server worked well before beta 2.
AS3.0b2: problem connecting Filezilla FTP server
Registered Salamander user.
Re: AS3.0b2: problem connecting Filezilla FTP server
What version of Filezilla FTP server are you using? Is it possible to update to current version 0.9.41? I have tested Salamander with Filezilla FTP server and it has worked well.
Seems my version was corrupted or outdated, now it works well for me, too. Thanks!
