Dropbox Support
						Dropbox Support
			One of the most popular file syncing sites out there is Dropbox.
http://www.dropbox.com/
In Windows Explorer DropBox puts a nice Library or shorcute right in the main display for Easy Access. I would love if an easy access icon could be put where the Documents, FTP CLient , SCP, Windows Registry shortcuts are in the Drive dropdown?
Melloware Inc.
http://www.melloware.com
						Melloware Inc.
Re: Dropbox Support
Why not create a Hot Path for it? Hot Paths are displayed on the bottom of the drive selection menu.
						Re: Dropbox Support
I do have a hotpath for it but on every single machine I set up with Salamander I have to create this Hotpath. I would love it if it just knew I had Dropbox and put the custom icon there with shortcut like ";" if for My Documents.Ether wrote:Why not create a Hot Path for it? Hot Paths are displayed on the bottom of the drive selection menu.
Melloware Inc.
						Melloware Inc.
Re: Dropbox Support
I add vote for DropBox support, too.
It will be nice have item in Alt+F1 menu.
PS: All hotpaths are occupied for me.
PepaR
						Re: Dropbox Support
Isn't this something, that is better to be done by scripting? Especially, since there is several other free cloud providers, too.
							Bye,
Andreas
						Andreas
Re: Dropbox Support
I guess no one is interested in this one.   I could look at making a plugin in the future but just do not have the time now.
Melloware Inc.
						Melloware Inc.
Re: Dropbox Support
(Just to note & no I have not used it: CarotDAV is a Simple WebDAV / FTP / SkyDrive / DropBox / GoogleDrive / Box / SugarSync client.)
Re: Dropbox Support
This idea isn't about cloud storage client. It is about putting path to cloud storage local directory into Alt+F1 menu.
From AS3.0b2 there is SQLITE3 database engine included in AS package (was needed for Google Drive fix) - utils\sqlite.dll. We can read Google Drive and Dropbox configurations (both sqlite db) and get the local directory.
Re: Dropbox Support
Hi Jan,
so what do you mean with your answer, are you going to put support for this in Salamander?
Regards,
Kris
Regards,
Kris
Re: Dropbox Support
We like this idea, I hope we will find some time to implement it.
						Re: Dropbox Support
Brilliant, sounds great Jan, thank you for letting us know!!!
						Re: Dropbox Support
Awesome thanks for the response!
Melloware Inc.
						Melloware Inc.
Re: Dropbox Support
I'd rather support some similar open source project than such commercial, closed-source ones associated with NSA.
