Missing network drives letters [as30b1x86 + W8 64]
dsznajder
Post by dsznajder »
I map network drive in Windows 8:
Mapped drive
Mapped drive
but this drive (V:) not appears in AS drive list:
Drive list
Drive list
Also "change directory" not see this drive:
Error when cd
Error when cd
but shell see:
shell - cd OK
shell - cd OK
AS 3.0 B1 32-bits running on W8 64-bits.
Dariusz Sznajder
Brett
Re: Missing network drives letters [as30b1x86 + W8 64]
Post by Brett »
I found that running AS 3.0 as Administrator did not show any mapped drives in the drive list but running without Administrator rights did show them. This is a contrast to what I experienced with AS 2.54 running as Administrator which is a PITA as I now have to run a second copy of AS 3 with Administrator rights in order to carry out certain tasks.
Could this be what is happening to you as well ?
Cheers,
Brett
dsznajder
Post by dsznajder »
Brett wrote:I found that running AS 3.0 as Administrator did not show any mapped drives in the drive list but running without Administrator rights did show them. This is a contrast to what I experienced with AS 2.54 running as Administrator which is a PITA as I now have to run a second copy of AS 3 with Administrator rights in order to carry out certain tasks.
You are right, this issue exist only when AS 3.0 is running with administrator rights. Strange.
But I just check AS 2.54 and it behaves in same way as 3.0 in my case - I see network drives when it is running as normal user and not see when running with administrator rights.
Dariusz Sznajder
darilek
Post by darilek »
to enable mapped drives in W8 under admin context just follow these steps:
- disable UAC
- modify Altap Salamander shortcut to run as Admin by default (via properties dialog)
- modify registry - add/modify entry EnableLinkedConnections under [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System] fillded with DWORD value "1"
registry tweak included as attachment
AllowNetShareUnderAdminContext.zip
(364 Bytes) Downloaded 1328 times
-=:|MaD|:=-
dsznajder
[Solved] Re: Missing network drives letters [as30b1x86 + W8
Post by dsznajder »
darilek wrote:to enable mapped drives in W8 under admin context just follow these steps:
- disable UAC
Thank you.
A just found also workaround here: http://forum.altap.cz/viewtopic.php?f=2&t=4085#p20346
SelfMan wrote: This is becaute drive mapping works under user context.
If you run something as administrator, you are runnig it as a different user.
Indeed - when I do "Connect network drive" from AS running as Administrator then I have letter in AS and... not have letter in Explorer.
So I just map same network share with same letter twice and now it looks OK.
Probably in W7 it behaves in same way and probably I do the same thing just without thinking too much :-)
Dariusz Sznajder
Brett
Post by Brett »
I tried mapping the network drives a second time through Salamander run as Administrator but after a restart they disappeared again.
I found that the solution given above
and a reboot has solved my problem.
Cheers,
Brett
