GodMode toolbar button
omega
Post by omega » 20 Jun 2011, 02:07
Would it be possible to create a toolbar button for GodMode, a feature found in vista and win 7 ?
otrov
Re: GodMode toolbar button
Post by otrov » 20 Jun 2011, 02:51
You can create handy folder, then from Mode.{ED7BA470-8E54-465E-825C-99712043E01C} copy all item there. It will create shortcuts in that folder to all items from Mode.{###}
omega
Post by omega » 20 Jun 2011, 15:00
Yes i know you can create a directory and copy all the shortcuts to the new directory and then create a hotpath. What you don't get is the categories that you see when you open the GodMode directory in windows explorer. So an optional GodMode toolbar button is something nice to have just like the control panel toolbar button. :)
th.
Post by th. » 20 Jun 2011, 16:45
You can create a User Menu entry:
Command: explorer
Arguments: shell:::{ED7BA470-8E54-465E-825C-99712043E01C}
Execute through shell: unchecked
omega
Post by omega » 20 Jun 2011, 17:39
Cool, thanks mate. :D
