Hi
I am using the oilister viewer plug-in with the Total Commander Proxy, specially for office documents like docx and xlsx.
Upon first usage it takes quite some time to load.
Is there a way to set a plug-in to auto-load when Salamander starts?
Thanks
McL
Autoload Plugin
Re: Autoload Plugin
It could be done only in the plugin source code.
CSalamanderGeneralAbstract::SetFlagLoadOnSalamanderStart()
Re: Autoload Plugin
Or as a setting (but still needs changes in the plugin source code *) - see the Check Version plugin connection settings.
*] make a request in the TC Proxy plugin thread
