Total Commander Proxy Plugin
Re: Total Commander Proxy Plugin
SynUS doesn't work for me in AS.
darilek
Post by darilek »
Jan Rysavy wrote:Do you mean SynUs?
no I'm using this one: http://www.totalcmd.net/plugring/syn2.html
-=:|MaD|:=-
Hi, I'm using some wcx plugins + TC proxy in AS but I found, that for some reason there is no available to use "pack" command from AS. I'm able to copy files from archive with TC Proxy + wcx plugin, but I'm not able to copy file back to archive. For example mpq.wcx (http://www.zezula.net). is is problem od proxy, as or something else?
manison
Post by manison »
Unfortunately the proxy plugin does not support the packing function yet.
manison wrote:Unfortunately the proxy plugin does not support the packing function yet.
Any chance to implement it? :-)
manison
Post by manison »
I'll review my to-do list and check out how much effort would this involve.
manison
Post by manison »
Updated version of the Total Commander Proxy plugin is available for download. This version extends support for WCX plugins. Packing to and deleting from archive in panel and packing and unpacking from dialog is now supported.
otrov
Post by otrov »
Thanks for this plugin, it's great. I finally see my mobile (old Nokia) in file list, among other fine solutions :)
I wanted to ask, has anyone managed working temp panel?
I tried three different TC plugins:
- TempPanel.wfx
- TempDrive.wfx
- VirtualPanel.wfx
They all failed in doing anything and when file is copied to panel it freezes salamander and must be terminated with task manager
McLion
Post by McLion »
I tried to set it up again with the Office 2007 plugin on my new PC.
Somehow it does not work anymore. Any hints?
Thanks
otrov
Post by otrov »
Here is new plugin which works great in AS thanks to this bridge: http://rghost.net/users/arax/releases/Outside-In-Lister
Outside In Lister is a powerful document viewer based on Oracle® Outside In Viewer
that can access the information in more than 500 file formats.
[edit] -----------------------------------------------------
I wanted to check for update on this TC plugin and noticed that above link is broken
Also to save possible AS user trouble, here are quick steps I needed to update/install this plugin:
- plugin name is changed from "oilister" to "ulister"
1. download from here: http://www.totalcmd.net/plugring/oilister.html
2. open "readme.html" file from downloaded archive and follow installation instruction; in summary - why make things simple when we can complicate (though probably licence issue):
- create Oracle account
- now you can download desired archives
- copy all files from "..\redist" folders to TC plugin folder
- associate desired files in AS viewer settings
This version is much faster on my PC, so I'd recommend update although above end-user installation trouble
McLion
Post by McLion »
... and how to load ... missing the language file in the lang folder ?
otrov
Post by otrov »
1. make subfolder for your TC plugin in AS plugins folder
2. copy there all TC plugin files
3. copy also tcproxy.spl
4. make additional subfolder named "lang" and copy "english.slg" inside
example structure for sumatraPDF plugin:
>dir/b/s
C:\Program Files\Altap Salamander\plugins\wlx_sumatraPDF\pluginst.inf
C:\Program Files\Altap Salamander\plugins\wlx_sumatraPDF\SumatraPDF.wlx
C:\Program Files\Altap Salamander\plugins\wlx_sumatraPDF\tcproxy.spl
C:\Program Files\Altap Salamander\plugins\wlx_sumatraPDF\lang
C:\Program Files\Altap Salamander\plugins\wlx_sumatraPDF\lang\english.slg
McLion
Post by McLion »
so far .. thats what I did ... and where to get the correct english.slg because that is what I am missing?
manison
Post by manison »
The english.slg file is part of the tcproxy.zip archive you can download from the first post. Just follow the installation instructions from the readme.txt file you will find in that archive and let us know if you encounter any problem.
McLion
Post by McLion »
Great! Works! Thanks!
I had the idea that the slg must come from the actual plugin that is loaded by tcproxy.
