In AS 2.54 Paste (Change Directory) does not work if the path is surrounded by double quotes.
I don't know about the behaviour in earlier versions, but AS should cope with quoted paths, as this is the standard for paths with whitespaces in most cases.
Change Path by Pasting
Re: Change Path by Pasting
Just curious, in what circumstances are you coming across paths with quotes?
+1
For example copy of target path of any shorcut of anything within Program files folder.therube wrote:Just curious, in what circumstances are you coming across paths with quotes?
I will move this thread to Feature requests section. I'm missing the double quotes stripping too.
I'd like to bump this issue.
As I see it, it is just a small and local change ... please do it.
Fixed. Will be included in AS 2.55 EAP.
