Column with another language in Texts window
Forum rules
Can you add Column with another language in Texts window to compare translated text?
Re: Column with another language in Texts window
Not sure what you mean?
There are only original and translated texts, so two columns. What should be in the third column?
Note: you can start two instances of Altap Translator with different projects. This way it is possible to compare two (or more) translations.
