Missing offset value in hex view (Viewer)
Evin
Post by Evin »
This problem exist, I think, since the AS 2.5. In Viewer I can't see the offset value in the last some lines, if I leave the cursor on the hex value. In the first lines it works fine.
Re: Missing offset value in hex view (Viewer)
I have trouble understanding what you mean. I opened a file in the Internal Viewer in hex mode and left the mouse cursor on the offsets (the values in the leftmost column) and nothing happened regardless of which line it was. I'm not sure what's supposed to (not) happen. Could you attach a screenshot of both cases?
I have just tested it and it has worked fine here. Please post here how to reproduce it and attach some test file. This bug may be dependent on file size. Thanks!
Evin
Post by Evin »
I think the size doesn't matter. I tested with 3 files: <1MB, 2MB, 3.2GB. Always the same. Under up to date Xp SP3 or Win7. And of course not cracked or something OS.
This is last line, where I can see the offset value. In line 270 or under I can't see this yellow popup "block".
Evin wrote:I think the size doesn't matter. I tested with 3 files: <1MB, 2MB, 3.2GB. Always the same. Under up to date Xp SP3 or Win7. And of course not cracked or something OS.
Ahaaa, the tooltip with offset doesn't get displayed. I think I can reproduce it.
It seems to me, that the tooltip does not display under rectangle of the size of "restored" (i.e. not maximized) window of Altap Salamander. Does that make sense?
1) have AS in a restored size
2) open the Internal viewer and slightly enlarge it at the bottom
3) the tooltip shows up only in the area of the original size
4) close the viewer, enlarge the main window of AS and repeat steps 2) & 3). The same problem with the new size.
5) close the viewer, maximize the main window of AS and repeat steps 2) & 3). The same problem, but the original size of the main window is still taken into account.
I can reproduce it, I'll look at it. Thanks!
I have fixed it, we have not set tooltip bounding rectangle properly. Thanks for reporting this!
