File comparator for .xml
TÜV
Post by TÜV »
F3 in Altap Salamander 2.53 beta 1 shows the content of .xml-files in a good way (colored, using the Internet Explorer).
Alt-F3 can show the file-content with Wrap (Ctrl+W).
But the Plugin "File Comparator" shows the content of .xml-files only with line 1 (short header) and a very long line 2.
Could you improve this by adding the option Wrap (Ctrl+W) also in the File Comparator?
Could you add ">" as selectable under "Line Ends" in the options of the File Comparator (and of the Internal Viewer)?
Re: File comparator for .xml
Can you post sample files where this occurs?
(Thinking there are enough variances between "xml" that what one may see, another may not.)
Wrap could be beneficial.
Horizontal (Ctrl+H) may help in some instances.
TÜV
Post by TÜV »
I got "The extension xml is not allowed." when trying to upload an .xml-file. So I zipped it.
document.zip
this is from inside a .docx-file
(2.55 KiB) Downloaded 751 times
TÜV
Post by TÜV »
you may need the second file to compare
document2.zip
from inside a changed .docx-file
(2.66 KiB) Downloaded 740 times
The "1 (short header) and a very long line 2" threw me initially.
Perhaps a layout like that is not typical?
Attached are two versions of "branding.xml" from Office 2007.
The majority of the file "works" as expected, but then there are a few ~170K character lines too (at the end of the file, & a couple shorter lines at the top).
(Comparator likely will never finish so ESC after a few seconds, choosing to run it in with Detailed Differences off.)
In this case treating ">" as end EOL character could help.
Various utilities (editors, Vim, or UNIX-like utils, sed or whatever) & you could "manually" reformat the file before comparing.
%s/>/&\r/g
& your document.xml would end up like document.revised.xml.
document.revised.zip
Manually revised document.xml replacing ">" with newlines. EDIT: Now with both files enclosed.
(5.37 KiB) Downloaded 711 times
branding.zip
A pair of xml's that are laid out in a readable manner, except for a few extremely long lines.
(193.95 KiB) Downloaded 714 times
TÜV
Post by TÜV »
Comparing your 2 files with "Show only Differences" shows also lines with no differences.
Switching to "Horizontal View" does not refresh the whole display (leftovers of linenumbers).
Also other xml-files have no linefeeds (like your files have), see the attachment meta-xml.zip.
meta-xml.zip
xml without linefeeds
(801 Bytes) Downloaded 723 times
wrong display of file comparator
TÜV
Post by TÜV »
With the 2 German language xml-files in the attached zip-file (from 2 old versions of PDF-XChange Viewer) the File Comparator plugin works fine, although there are no linefeeds in it.
But the internal file viewer of Salamander 2.53 beta 1 shows wrong German signs (ÄÖÜäöüß) and the Internet Explorer (with F3) has a problem to show the end of the older file version (42.7).
PDFXVW_De_42.7-8.zip
2 similar German Language xml-files
(66.31 KiB) Downloaded 729 times
Sure there are, $0a$ = LF.
TÜV
Post by TÜV »
You are right. I looked at it with F4 of Salamander and there were no linefeeds to be seen.
TÜV wrote:Comparing your 2 files with "Show only Differences" shows also lines with no differences.
This has been fixed for the next version of Salamander (AS 2.53b2/2.53).
