Delay after every file operation
Dear Forum!
Using Salamander 2.52, I experience a delay of about 1 s after every file operation (copy, move, etc.).
This delay acts like a brake that prevents me from using Salamander within this 1 s.
The program just does not react.
The behaviour is the same on local and remote drives.
How can I get rid of this delay?
It really dampens my productivity.
Am I missing something fundamental?
Thanks for any help in advance
Tim
Tim
Re: Delay after every file operation
Tim, what about operations such as View File or Change Attributes?
Please try to disable Options > Configuration > Icon Overlays > Display custom icon overlays option.
Thanks for your input, Raptor.
Tested turning off ESET.
No change in behaviour.
Unfortunately, it must be something else.
Cheers
Tim
Cheers
Tim
Has already been reported HERE
Thanks for telling me.SelfMan wrote:Has already been reported HERE
Reported, but not solved.
Cheers
Tim
Jan Rysavy wrote:Tim, what about operations such as View File or Change Attributes?
Thanks, Jan.
OK, turned it off.
Now, the delay seems even longer.
What's going on here ... ?
A similar problem has been discussed HERE
Just search for delay or lag as keywords.
Have you restarted salamander after the configuration change?Tim wrote:Jan Rysavy wrote:Tim, what about operations such as View File or Change Attributes?
Thanks, Jan.
OK, turned it off.
Tim, your first posts are from 2006. Did you notice these delays before AS 2.52?
Or, does it start with installation of AS 2.52?
And here http://forum.altap.cz/viewtopic.php?f=2&t=3053SelfMan wrote:A similar problem has been discussed HERE
SelfMan wrote:Have you restarted salamander after the configuration change?Tim wrote:Jan Rysavy wrote:Tim, what about operations such as View File or Change Attributes?
Thanks, Jan.
OK, turned it off.
Yes!
Not sure, but I guess it started with 2.52 (Beta).Jan Rysavy wrote:Tim, your first posts are from 2006. Did you notice these delays before AS 2.52?
What OS are you on? Which version of ESET Antivirus/ESS do you have?
Are you using any programs with shell extensions like TortoiseCVS/SVN?
Could you please test older versions? (Install it to some temporary directory.)
AS 2.51: ftp://ftp.altap.cz/pub/altap/salamand/as251.exe
AS 2.5: ftp://ftp.altap.cz/pub/altap/salamand/as25.exe
