Total Commander Proxy Plugin
Re: Total Commander Proxy Plugin
wsorg wrote:Total Commander Proxy Plugin pro Altap Salamander does not work with new version Altap Salamander 2.52 Final.
It works fine, please use version for Altap Salamander 2.51 (AS 2.52 is backward compatible with 2.5 and 2.51 plugins).
wsorg
Post by wsorg »
Thanks!!!
Yes really all works, but it is quite good to make the new version of a plugin.
It would be great if Manison could update plugin description (compatible with AS 2.51 and further versions) and remove 2.52 beta 1 version (AS 2.51b1 just expired). That's all.
manison
Post by manison »
Done. The updated version is compatible with Altap Salamander 2.51 and later and also contains minor bugfixes.
gem45
Post by gem45 »
Thanks for the information
CanonCam is functionally. it works great.
Thank you.
Reason: Removed link.
manison
Post by manison »
New version of the Total Commender Proxy plugin is available for download. This version includes a brand new Total Commander plugin installation wizard, implements the delete function for the file system plugins and also fixes some bugs. For the complete list of changes see the history.txt file included in the package.
vld
Post by vld »
Very nice.
Is this still only compatible with Salamander v2.51 and newer?
manison
Post by manison »
vld wrote:Very nice.
Should be compatible with 2.5+, however tested on 2.52 and PB38 only.
vld
Post by vld »
Ran a quick test and appears to work with v2.5
manison
Post by manison »
vld wrote:Ran a quick test and appears to work with v2.5
Thanks for the confirmation. BTW, any reason to stick with 2.5?
vld
Post by vld »
actually I have 2.0, 2.5, 2.51, & 2.52 all in their own folders....just in case I find a glitch and want to verify with previous versions.
vld wrote:actually I have 2.0, 2.5, 2.51, & 2.52 all in their own folders....just in case I find a glitch and want to verify with previous versions.
:wink:
manison
Post by manison »
New version of the Total Commander Proxy plugin is available for download. This version fixes problem reported with NokiaFS plugin. Copying directory trees from local file system to the plugin should now work.
darilek
Post by darilek »
manison wrote:New version of the Total Commander Proxy plugin is available for download. This version fixes problem reported with NokiaFS plugin. Copying directory trees from local file system to the plugin should now work.
many thanks, i started using your proxy plugin with TC Syn2 lister plugin. I replaced AS internal viewer with this. It is fast, supports syntax highlighting, UTF8 :D
-=:|MaD|:=-
Do you mean SynUs?
