PictView: ScreenShot tool issues - bugs
Georgd
Post by Georgd »
Moved from http://forum.altap.cz/viewtopic.php?p=6253#6253
"Screen capture => Foreground Application" has a flaw (see screenshots attached). It does not care about dialogs, so it captures only the Salamander rectange and ignores the dialog that is part of Salamander. Even though when dialog is modal and has the focus and hides parts of the rectangle being captured :( WinSnap (http://www.ntwind.com/software/winsnap/) handles this feature as I expect it to work, so it might serve as an inspiration.
Image Image
/Georg
Thank you for this bug report!
Georgd
Re: PictView: ScreenShot tool issues - bugs
Post by Georgd »
still not fixed :?
Using Salamander since v 1.52
