When I compare two files, the File comparator (plugin) window gets positioned too far to the left, under my (vertical!) Windows button bar:
[attachment=0]Lower part of the screen.png[/attachment]
File comparator window position
- The lower part of my screen
- Lower part of the screen.png (33.68 KiB) Viewed 15367 times
Groente, Michel.
Re: File comparator window position
Interesting. It appears that FileComp does not honor non-auto-hiding TaskBar (when on top or left side) when it positions its window.mdruiter wrote:When I compare two files, the File comparator (plugin) window gets positioned too far to the left, under my (vertical!) Windows button bar:
It looks like incompatible functions' return values and parameters.Jan Patera wrote:Interesting. It appears that FileComp does not honor non-auto-hiding TaskBar (when on top or left side) when it positions its window.
mdruiter, what about internal text viewer (F3 on text file), does it open exactly above Salamander?
The internal text viewer, PictView and Eroiica Viewer all position correctly: exactly above Salamander.
Groente, Michel.
It seems to be similar problem as was in internal beta of DiskMap plugin (v0.5.25) - by using GetWindowPlacement() (which uses workspace coordinates) instead of GetWindowRect() which uses screen coordinates, which are usable by CreateWindow() taht uses screen coordinates as well.
The problem has been fixed for the next version of Salamander (2.52).Jan Patera wrote:Interesting. It appears that FileComp does not honor non-auto-hiding TaskBar (when on top or left side) when it positions its window.mdruiter wrote:When I compare two files, the File comparator (plugin) window gets positioned too far to the left, under my (vertical!) Windows button bar:
