Multimedia viewer: Cover view
Ability to show the cover (if available) in mp3-files.
Kind regards, KNUT
Re: Multimedia viewer: Cover view
Can you please be more specific what exactly you mean by "cover"? Do you mean the album art saved in a JPEG file by various MP3 players in a separate file next to the MP3 files? If not, can you plase send me a sample file?KNUT wrote:Ability to show the cover (if available) in mp3-files.
He thinks implementation of ID3V2 tag with extended information.
http://www.id3.org/Developer_Information
I mean the embedded image inside the mp3-file, not in a seperate file. Here's an example.Jan Patera wrote:Can you please be more specific what exactly you mean by "cover"? Do you mean the album art saved in a JPEG file by various MP3 players in a separate file next to the MP3 files? If not, can you plase send me a sample file?KNUT wrote:Ability to show the cover (if available) in mp3-files.
Kind regards, KNUT
Jan, any chance to add this feature to the Multimedia viewer? Please...Jan Patera wrote:Can you please be more specific what exactly you mean by "cover"? Do you mean the album art saved in a JPEG file by various MP3 players in a separate file next to the MP3 files? If not, can you plase send me a sample file?KNUT wrote:Ability to show the cover (if available) in mp3-files.
Kind regards, KNUT
