Bug: submission order of multi-file selection
I selected several mp3 files in Salamander, right-clicked on one of them, and selected Play in Winamp. The files got inserted into Winamp's play list; however, the first file in the play list happened to be the one I clicked on in Salamander, which was out of desired order. The selection should be acted upon regardless which element (file or directory) is clicked on.
This new behavior is fix of old bug. The focused file is given as first. Try Windows Explorer, it behaves the same way.
I just discovered we didn't fix the problem properly in AS 2.52 beta 1.
When you select 4 files and open context menu with focus on file 3:
1 (selected)
2 (selected)
3 (selected & focused)
4 (selected)
you will get following order in WinAMP:
AS 2.51: 1, 2, 3, 4
AS 2.52b1: 3, 1, 2, 4
Explorer: 3, 4, 1, 2
We will fix this problem in AS 2.52b2.
Btw, the Foobar2000 v0.9.6.2 is handling this situation the same way as you are expecting. Always in order 1, 2, 3, 4. It doesn't matter which file is focused. Great player.
1 (selected)
2 (selected)
4 (selected)
AS 2.51: 1, 2, 3, 4
+1 from me.ino wrote:I thing AS should not copy all "strange" behaviour from MSExplorer.SelfMan wrote:I prefere the "old" 1,2,3,4 way.
+1 from me
+1
This is not related to WinAmp from my point of view - I am having the same issue with Win Media Player. Generally, anytime I select a buch of files to do some action, I really mean to have it done on the files in the order they are showing in the panel, not from the focused one.
Changing it to 3, 4, 1, 2 sounds even less useful for me. Well, maybe because I never used Explorer, but Salamander all the time
Please make the Explorer-like behavior at most optional, not the only one possible for everybody.
Thanks,
Ondřej
I've just checked the behavior and get the 3,4,1,2 in AS2.52b1 (2.5.2.18) and WinAMP 2.91 (I know... a OOOLLLD version, but not that bloated and working...)Jan Rysavy wrote:When you select 4 files and open context menu with focus on file 3:
1 (selected)
2 (selected)
4 (selected)
AS 2.51: 1, 2, 3, 4
pjj
