Change attribute - slow?
Hello
Has anyone noticed that AS25 (2.51, 2.52b1) perhaps older versions just hang a second or two each time you try to change file attributes of a file with the ctrl+f2 switch?
please note that these files are not in use. trying to change attributes with "attrib -r filename" is way faster than AS25
Please advise,
Elias
Please advise,
Elias
Could you reproduce this problem also on directory?lallous wrote:I just tried ctrl+f2 to remove archive bit and it works fast.
apparently, it is slow when I remove read-only bit.
Could you please also check Hidden and System attributes?
The operating system is Windows XP?
Hello,
1.
I attached a debugger and when I try to rename several RaiseException() calls were observed, here's the callstack:
WINDBG>k
ChildEBP RetAddr
08bee200 004dac19 kernel32!RaiseException+0x53
WARNING: Stack unwind information not available. Following frames may be wrong.
08bee24c 004dac3e salamand+0xdac19
08beeb8c 0040d9d9 salamand+0xdac3e
08beebbc 0040da46 salamand+0xd9d9
08beff80 23907af9 salamand+0xda46
08beffb4 7c80b713 SALRTL!beginthreadex+0xca
08beffec 00000000 kernel32!BaseThreadStart+0x37
another RaiseException() callstack:
06cceb10 004dac3e salamand+0xdac19
06cceb44 004b7b2d salamand+0xdac3e
06cceb60 004b7b85 salamand+0xb7b2d
06cceba0 004b7bfc salamand+0xb7b85
06ccff68 2241548f salamand+0xb7bfc
06ccffb4 7c80b713 regedt!SalamanderPluginEntry+0x2d72
06ccffec 00000000 kernel32!BaseThreadStart+0x37
Then I wanted to see if there is any explicit calls to Sleep() and indeed:
salamand.exe:00443A64 mov byte ptr [ebp+var_4], 2
salamand.exe:00443A68 cmp eax, ebx
salamand.exe:00443A6A mov [esi+540h], ebx
salamand.exe:00443A70 jbe short loc_443A79
salamand.exe:00443A72 push eax
salamand.exe:00443A73 call Sleep
Here's log to Sleep() calls:
Sleep(30)
7C8106E9: thread has started (tid=3940)
7C8106E9: thread has started (tid=3944)
Debugger: thread 3944 has exited (code 0)
Debugger: thread 3940 has exited (code 0)
Debugger: loaded C:\WINDOWS\system32\psapi.dll
Debugger: unloaded C:\WINDOWS\system32\psapi.dll
Sleep(30)
7C8106E9: thread has started (tid=2748)
7C8106E9: thread has started (tid=2752)
Debugger: thread 2752 has exited (code 0)
Debugger: thread 2748 has exited (code 0)
Sleep(30)
Sleep(60000)
7C8106E9: thread has started (tid=3424)
7C8106E9: thread has started (tid=3432)
Notice, that sometimes Sleep is called with 60000 MS -> 1 second
Under the debugger, the delay behavior changed, but still occasionally an exception occurs and Sleep() with higher intervals is used.
2.
Jan: tried with many files, no delay, it was fast, and the Sleep() calls were with interval = 30ms
3.
nonstandard shell extension? yes, WinRar, winZip, perforce (but on my home pc i don' thave perforce and still same rename issue)
Selfman: RCS = Perforce
Please advise about the exceptions / delays in the code.
Regards,
Elias
						1.
WINDBG>k
ChildEBP RetAddr
Sleep(30)
Sleep(30)
Sleep(30)
Sleep(60000)
2.
3.
Regards,
Elias
Thank you for the feedback.
When you select two (or more) files and do the same, there is no delay?
Could you please confirm it?
						You probably mean 1 minute. Did you notice some 60s delays?lallous wrote:Notice, that sometimes Sleep is called with 60000 MS -> 1 second
Are we talking about AS 2.52 beta 1?lallous wrote:salamand.exe:00443A64 mov byte ptr [ebp+var_4], 2
So when you select just one file (no other file is selected) and press Ctrl+F2 and remove the Read-only attribute, you notice the 2s delay.lallous wrote:Jan: tried with many files, no delay, it was fast, and the Sleep() calls were with interval = 30ms
You are right, 1 minute, however it is weird that a 60000 delay (1 minute) was logged but it did not take place, it was a second or two freeze. Probably it was the time spent in exception handling.
Yes, AS2.52b1
"So when you select just one file (no other file is selected) and press Ctrl+F2 and remove the Read-only attribute, you notice the 2s delay. "
It is happening randomly, after I restarted my PC and attached a debugger to AS252b1 exceptions occured on rename and the delay was experienced.
After I repeat couple of times no more exceptions and no more delays.
On another PC I have same delay issue.
So the delay is not related to the number of files, it could happen with one file or more, you don't see progress bar, but AS252 just freezes for at most 2secs.
						Yes, AS2.52b1
I thought I did,
* You probably mean 1 minute. Did you notice some 60s delays?
as said, no, just one or two secs
* Are we talking about AS 2.52 beta 1?
yes,
* So when you select just one file (no other file is selected) and press Ctrl+F2 and remove the Read-only attribute, you notice the 2s delay.
one file or many files, it happens when removing readonly attribute.
if debugger is attached, this behavior manifests only one time, then works normally.
finally, if i need to reproduce this, I would have to restart my PC. If I don't attach a debugger, it will keep on wasting 2 secs on each rename. if i attach dbg once, then the wait happens once.
if you need more feedback plz tell me.
yes,
