Shell Menu Plugin
stepand76
Shell Menu Plugin
Post by stepand76 »
Shell Menu is simple plugin that allows you to register Altap Salamander to the Windows shell menu.
Plugin is available here:
http://sites.google.com/site/stepand76/asplugins-enu
You can discuss the plugin in this thread.
Any comments, suggestions and feature requests are welcome.
stepand76
Post by stepand76 »
Version 1.1.0 (28.1.2009)
[+] Texts moved to SLG file (now it is possible to translate plugin to other languages).
[+] Added version information (VERSION_INFO) into plugin binnary files.
[+] Added plugin icon.
[-] Fixed showing of message dialogs (icon, set of buttons).
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancement
stepand76
Post by stepand76 »
Version 1.2.0 (4.2.2009)
[+] Added compatibility with AS 2.52 beta 1.
[*] Changed registration of shell menu. Command line is: <SALAMANDER_PATH> -A "%1" -O
    This change will take effect after re-registration ("Register Altap Salamader" command).
Legend
[*] Change
[-] Bugfix
stepand76
Re: Shell Menu Plugin
Post by stepand76 »
Version 1.3.0 (24.8.2009)
[*] Fixed compatibility with AS 2.5, 2.51 and 2.52 beta 2.
Legend
[*] Change
[-] Bugfix
stepand76
Post by stepand76 »
Version 1.4.0 (4.3.2010)
[*] Built with Delphi 2010.
[+] Enhanced "About" window.
Legend
[*] Change
[-] Bugfix
shellmenu_1.4.0.zip
(365.82 KiB) Downloaded 2547 times
natri23
Post by natri23 »
plz update this to the latest beta
