Standard windows folder-icons instead of custom ones,Beta 11
KNUT
Post by KNUT »
As mazy mentioned here::
mazy wrote:jan perhac, i can see you have changed quite a few icon resources ;). i have small problem with folder icons in salamander, it uses standard windows' ones instead of my custom ones (which i can see in explorer and other places). what should i do?
Same problem here :(
Any help / idea?
mazy
Post by mazy »
KNUT, did you have custom icons in previous betas (i didn't).
it seems salamander is getting these icons directly from shell32.dll, so one would have to modify them there.
it's not a big deal, however it would be nice to use custom (theme) icons, not the shell32.dll ones. would look better with my dark theme ;).
Could you please describe me how to reproduce this problem?
Servant Salamander displays different icons then Windows Explorer?
KNUT
Post by KNUT »
I must ask for a pardon :? I can see my custom icons.
I'm sorry for this confusion...
:oops:
Kind regards, KNUT
mazy
Post by mazy »
KNUT, so what was the problem?
Jan Rysavy, as far as i remember, salamander always used the default icons and not the custom ones. i have windows xp and i use stardock's iconpackager to create and change icon sets.
the icons i use are smooth metal. i've tried using other ones, rebuilding icon cache etc. - with the same result.
i can see these custom icons in explorer. salamander shows only custom icons for folders like favorites, but not for normal folders.
screenshot here.
