It is a useful feature that I can right click and copy the entire or a partial path to the clipboard.
But, on network drives, I'd prefer it to copy the UNC path, "\\monster\data\source" instead of "F:\Source". My colleges may not have the drives mapped the same way.
The copy path to clipboard function
- UNC_Path.JPG (12.64 KiB) Viewed 10884 times
Re: The copy path to clipboard function
Use CTRL+SHIFT+INSERT (See the Edit-menu for all options!)hrc wrote:It is a useful feature that I can right click and copy the entire or a partial path to the clipboard. But, on network drives, I'd prefer it to copy the UNC path, "\\monster\data\source" instead of "F:\Source". My colleges may not have the drives mapped the same way.
Kind regards, KNUT
Guest
Did it do that?
The functionality was already there, fine.
When "copy to clipboard" on network drives I still think it should copy the UNC path. That way there's no uncertainty.
Using the <shift+ctrl+insert> shortcut I may have discovered a minor flaw. If I select a path and click on a file or directory before pressing <shift+ctrl+insert>, the path and filename is correctly copied onto the clipboard. Now select another network path. Using <shift+ctrl+insert> again, the previous path is pasted until a file or directory is selected. More logically it should copy the path with the filename.
BTW. I was a Salamander fan even before they began writing it! Beat that!
