WinSCP plugin - where are you? ;)
Re: as25fix3.zip corrupt?
Try to empty your cache and download it again, because this archive is ok. I think, that there must be problem on your side.wsadkin wrote:http://www.altap.cz/fix25/as25fix3.zip
seems to be corrupt; neither Salamander nor Winzip can open it. Is there something that can be done to at least fix this?
Please, compare your download with these parameters:
File Size = 773963
Time Stamp = 26.09.07 06:54:06
CRC = FF468849
MD5 = 980FEFDB206BA5AA5744125D09CA66B1
EDIT: I am sorry, I overlooked your post Jan.
Better than silencejis wrote:EDIT: I am sorry, I overlooked your post Jan.
Purchase pages for version 2.5 are nearly finished, we will finish them in half of November.
You can download new version of Altap Salamander 2.5. Reminder for unregistered plugins (WinSCP and PictView) is inactive until December 1, 2007.
Download it from: http://www.altap.cz/fix25/as25fix4.zip
Installation: replace original salamand.exe file in your Altap Salamander 2.5 installation with supplied new version of salamand.exe (overwrite it).
Guest
Just out of curiosity, why does salamand.exe need to be replaced? I'd assume winscp.spl would need to be replaced as this one is checking the plugin license.Petr Solin wrote:Installation: replace original salamand.exe file in your Altap Salamander 2.5 installation with supplied new version of salamand.exe (overwrite it).
Send me please as25fix3.zip
Hello I lost my backup. I missing this file: as25fix3.zip
Please send me as25fix3.zip to: tz(dot)jouda[at]centrum/dot\cz
Thnak You very much.
P.S. I have Fix1, Fix2 and Fix4. Missing Fix3 :'(.
Re: Send me please as25fix3.zip
What do you want to do with it? Start a collection?Jouda wrote:P.S. I have Fix1, Fix2 and Fix4. Missing Fix3 :'(.
These fixes do not depend on each other. Fix3 prolonged ability to use unregistered plugin till Nov. 1st. This date is history.
Fix4 prolonged it till Dec. 1st. I did not test anything, but according to the facts posted, the only possibility of using the plugin at his time is evaluation mode.
We are very sorry for all that delays. We have finally released these purchase pages: http://purchase.altap.cz/purchase/
