Chocolatey package for Altap Salamander
owilsky
Post by owilsky »
Hi there,
I created a Chocolatey package for Altap Salamander 2.54:
https://chocolatey.org/packages/altap-salamander/2.5.4
Chocolatey is a package manager for Windows, similar as apt-get for Debian Linux.
Once Chocolatey is installed (see here: https://chocolatey.org/), you can install Altap Salamander as easy as this:
cinst altap-salamander
If you as the company Altap have any problems with this, please let me know.
Oliver Kötter
Re: Chocolatey package for Altap Salamander
Nice. You should fix the Authors field.
owilsky
Post by owilsky »
Ether wrote:Nice. You should fix the Authors field.
Hmmm... you're right. I wrote "ALTAP, spol. s r.o." but the comma seems to be a separator for multiple authors, so I will remove the comma for the next version.
Oliver Kötter
fraktik
Post by fraktik »
Great - thanks to this post here I just found new awesome SW - work it "almost" like apt-get in linux.
My wet dream. I hope, that in some Win2020 will be this fully integrated (and working) - at least in GUI like Synaptic.
But back to the point - thanks to very slow way to "stable" (IMHO are last betas much more bug-free than 2.54) version AS v3.0 will be please possible to make package for some beta there too?
In two weeks we are expecting AS v3.0 beta 4, so... :D
Off topic:
Whole instalation is surprisingly easy - You just paste in cmd:
@powershell -NoProfile -ExecutionPolicy unrestricted -Command "iex ((new-object
net.webclient).DownloadString('https://chocolatey.org/install.ps1'))" && SET PATH=%PATH%;
%systemdrive%\chocolatey\bin
and than You just pick applications - I spend whole morning going trough repository (plus my Program Files) and my result is this simple command for reinstal majority of my apps (cca 100 of them, I am missing just something like 20 others):
cinst FoxitReader ChocolateyGUI 7zip vlc GoogleChrome Firefox skype pidgin Opera safari flash putty winscp notepadplusplus.install javaruntime flashplayeractivex flashplayerplugin adobereader ccleaner dropbox paint.net windirstat calibre libreoffice winmerge gimp wireshark procexp teamviewer iTunes winrar java.jdk foobar2000 k-litecodecpackbasic notepad2 spotify uTorrent defraggler Quicktime IrfanView speccy sumatrapdf imagemagick audacity googledrive adobeshockwaveplayer steam TotalCommander SkyDrive picasa Far ffmpeg malwarebytes XnView sumo mp3tag lastpass avastfreeantivirus PDFXChangeViewer treesizefree spybot ext2explore bleachbit songr spacesniffer adblockplusie OpenOffice clipgrab driverbooster aimp fsviewer adblockplusfirefox Folder_Size smplayer googleearth anydvd adblockpluschrome maxthon irfanviewplugins WindowsUpdate.DisableAutoRestart mumble drivergenius Teamspeak3 Kindle tomboy SwissFileKnife speedfan altap-salamander midori-browser inssider lastfmscrobbler teamviewer mobipocket.reader FBReader freeciv Ext2Fsd Silverlight camstudio
This is for BFU machine - but they have complete DEV support too.
owilsky
Post by owilsky »
I think we're even expecting beta 5.
I already made a package for 3.0 beta 4, you have to add the -pre parameter:
cinst altap-salamander-beta -pre
Oliver Kötter
fraktik
Post by fraktik »
Oh, my mistake - beta 4 is what is actually running on my PC just now.
Thx for cinst altap-salamander-beta -pre - but how is it, that I wasnt able to find this by https://chocolatey.org/packages?q=salamander ? Where to look (for more recent versions of packages)?
I found just 2.54 stable version.
I made new thread on chocolatey googleGroup too, so we can solve this there with other issues.
owilsky
Post by owilsky »
There's a combo box, default option while searching is "stable".
Oliver Kötter
fraktik
Post by fraktik »
Eh, my fault :(
I saw this box - I even changed it, but every refresh (and every new search or listing other page it jump back on "stable only") and I missed this... :evil:
owilsky
Post by owilsky »
3.0 final packages are uploaded now, package altap-salamander contains always latest stable version, package "altap-salamander-beta" always includes bleeding edge version, including alphas and betas. Right now the beta package has the stable version because this is the latest release ;-)
Simply update with "cup altap-salamander", "cup altap-salamander-beta" or even "cup all".
Oliver Kötter
