How to match tab while searching?
Posted: 17 May 2013, 00:42
I was searching for files containing regex pattern where Tab was one of the queries, and didn't get result although I knew there is at least one.
It turns out that AS in some places doesn't support common "\t", "\d", "\w", "\s" ... regex placeholders, but it treats them as literal character: "t", "d", ...
OTOH, in file rename dialog, using above regex pattern is without issue.
Why is it like this, and how can I search for Tab character with Internal Viewer for example?
