dot file extension
omega
dot file extension
Post by omega »
Lately there has been lots of discussions about the FLAME spyware. It uses a dot file extension which isn't visible in Windows Explorer. Does it mean that AS also won't be able to reveal this file?
The article can be found here http://labs.bitdefender.com/2012/06/fla ... an-vector/
Re: dot file extension
Salamander 2.54 and previous versions ignore name "." (dot) as "current directory" and it does not check if it is really directory. I have added this test to prepared version 3.0, so if "." is file, it will be displayed in panel as any other file.
