Right Pane Not Showing Files From Left Pane Folder
How do I get the right pane to display the files contained in the folder selected in the left pane? (the classic Windows Explorer view)
Re: Right Pane Not Showing Files From Left Pane Folder
You don't. Although you can open the contents of the focused directory in the other panel using the Ctrl+Shift+Right shortcut. Also you can set the left panel to show only directories (using the |* filter) in Brief view mode and set the other to Icons view mode. That's the closest thing to your idea I can think of.
Ctrl-Shift-Right Arrow does the job! Thanks!
