How to uninstall beta2 after install 2.53
TLJ
Post by TLJ »
Should I use Add/Remove Programs to uninstall 2.53 Beta2 after installing the official 2.53 release? Should I remove registry settings? Just want to make sure I don't mess something up...
Tony
Re: How to uninstall beta2 after install 2.53
Install Altap Salamander 2.53 first. It will import your 2.53 beta x settings and registration keys. It will install to C:\Program Files (x86)\Altap Salamander.
Start installed Altap Salamander 2.53 and ensure your settings and keys are imported.
Then you can uninstall the old (beta) version using Control Panel. It will offer removing configuration from Registry and registration keys from the disk (only for uninstalled version).
