Please make background refreshing an option, so I can get back the refresh on-window-activation as with AS <2.52.
Reason: I often use the ANT build tool in my IDE. Having the output directory shown in AS immediately aborts the ANT script (which first deletes the output directory to fill it again later).
Make background refreshing optional
Re: Make background refreshing optional
Do you have idea why is ANT script aborted by refresh of Salamander panel?
Most likely because AS somehow locks this directory and hence deleting in ANT (aka Java) fails.
Yes, I understand it and will try to make it optional.
Thanks in advance.
