Find Files List
Posted: 08 Jun 2016, 01:39
by rharding
The Find Files and Directories returns a list of all files that meet specified criteria. Is there a means of using the results of this command to perform tasks such as copying the selected files to another directory or zipping the files?
Thank you.
Richard
Re: Find Files List
Posted: 08 Jun 2016, 17:55
by therube
Select those you want...
Copy, then paste elsewhere.
I'd think most anything available on a context-menu, open-with, send-to would work too.
May run into issues if you have too many selected (as in won't be able to pass XX number of names to a particular application, kind of thing)?
Re: Find Files List
Posted: 15 Jun 2016, 03:24
by rharding
<<May run into issues if you have too many selected (as in won't be able to pass XX number of names to a particular application, kind of thing)>>
This was the problem. The message is displayed in Salamander that "some selected file or directory is not available" if a "large" number of files are selected.
Thank you
Richard
