Create Directory - Trailing dot, oddity, bug, feature?
Posted: 16 Jul 2015, 22:47
Create Directory - Trailing dot (.), oddity, bug, feature change?
> F7 -> R.E.M.
> Error: (123) The filename, directory name, or volume label syntax is incorrect.
Thought there might have been a change in that respect, but didn't find it.
No big deal... I understand whats going on.
SS 2.54 would create the directory, silently deleting the ".".
AS 3.06 gives you the error.
Shift+F4 -> R.E.M.
Creates a file "R.E.M" silently deleting the ".".
> F7 -> R.E.M.
Shift+F4 -> R.E.M.
