Anyone who knows how to convert a number e.g. "47061" to use it in find, search file content so excel documents containing the number will be found?
Using explorer search it works with just "47061" but it takes such a long time.
The format of the cells is general so it would have been a lot better if the format was text instead.
Altap Salamander is the best file manager there is.
/Peter
