Page 1 of 2
RC3 Quick Rename: Copying the name of file
Posted: 18 Apr 2007, 00:48
by jocare
With Salamander when I want to copy the name of a file, I press F2 and then Ctl+C, but this new version 2.5 RC3, When I press F2, it shows me the name of the file in a dialog box, but the extension is not selected. In al previous versions, the whole name was selected. What can I do so that when I press F2 both the name and the extension are already selected?[list][/list]
Posted: 18 Apr 2007, 01:31
This topic is currently under heavy discussion in the czech part of this forum. I believe that we will come to a usable solution for the final version.
Posted: 18 Apr 2007, 06:26
by maxovt
Theres is also command in Edit: "Copy Name as Text" (Alt+Shift+Insert)
"Make File List" (Ctrl+M) in Commands is usefull too.
Or just click with mouse on file name in Information Line.
Posted: 18 Apr 2007, 06:36
FOR ALL 2.5 RC3 USERS
For Czech-speaking users there is an
ongoing thread.
We introduced a new Quick Rename behavior for several reasons:
1. We think it is better for the renaming
2. We had several request from our users (for example
[1] [2] [3])
3. Windows Vista works the same way, it will become standard in a few years.
What we want to do now is support Ctrl+A (Select All) in this edit line.
We can also introduce a new option in the configuration to bring back old behavior.
Could you please let us know how you like new behavior?
Please specify: how do you use the Quick Rename command.
Example:
1. Mostly for copying name to clipboard, so new behavior is disturbing for me.
2. Sometimes for changing the name part (BEFORE: Ctrl+Left, Left, Shift+Home, type; NOW: type) so I welcome the change.
Please, let us know...
Posted: 18 Apr 2007, 11:40
by Klettermaxe
I like it the way it is now in RC3.
For copying filenames I use Alt+Shift+Insert. Copying filenames with F2 - Ctrl+C (and inserting the filename elsewhere with F2 - Ctrl+V) still works as before as long as the file-extensions of the source file and the destination file match.
Salamander already has a huge lot of options. If you think of making F2 more flexible, Strg+A in the edit field might be the more useful solution.
Posted: 18 Apr 2007, 13:01
by KNUT
Jan Rysavy wrote:Example:
Here's my vote:
2!
To copy the name I use Alt+Shift+Insert or the Information line!
Posted: 18 Apr 2007, 14:21
by Guest
I would be very happy to have "the option in the configuration to bring back old behavior."
Maybe I will get used to the new behavior... But being able to decide about the behavior myself would definitely be great!
Posted: 19 Apr 2007, 01:27
by SvA
My usage of quick rename is very varying. I guess I just as often use it to get the file name as to change the name part and as to change the extension part.
I would prefer the old behaviour, but with the new, I will get used to pressing ALT+SHIFT+INSERT and modified cursor moves to place carret/select filename parts.
An option to turn off the new behaviour would save me from having to relearn though, and thus, be wery welcome.
Posted: 19 Apr 2007, 02:00
by Guest
My vote goes to the new behaviour. I think that it is a real advantage, regarding the original purpose (quick rename). I think that I will quickly get used to other ways for copying the full name to the clipboard and CTRL+A will help me out when trying F2 like in the old days.
No option needed for me.
Posted: 19 Apr 2007, 17:54
by Sebastian
New behavior rocks!
@oldstyle-fans
Let the user choose is always the best choice, with this option noone has to complain
Maybe it is possible to set some shortcut to copy the filename straight to clipboard? For example, i didn't find anything related to "shift+f2", so maybe you can implement this and it is maybe quicker than the old style
Posted: 19 Apr 2007, 18:19
Try the Edit > Copy Name as Text (Alt+Shift+Insert) command or click on name in the
Information Line.
We plan to use Shift+F2 for the Duplicate command.
Posted: 19 Apr 2007, 18:50
by Textor
Jan Rysavy wrote:FOR ALL 2.5 RC3 USERS
Example:
I use "Quick Rename"/ F2 only for renaming files, because there are other methods (as mentioned) for copying a file name to the clipboard. The new method of selecting by default only the
name, not the .
ext helps with renaming, so I'm not missing the old one.
Adding a "Select All" function to the F2-dialog as proposed could also be useful for editing the file name, so I am in favor of this.
Posted: 19 Apr 2007, 23:26
In the czech part of this forum came a idea of a cyclic F2.
In example:
F2 > Select whole filename
F2 F2 > Select name
F2 F2 F2 > Select extension
Altap refused such implementation as non standard behavior, but I am interested in your opinions.
Posted: 19 Apr 2007, 23:37
by th.
Since I'm using F2 only to rename a file and in most cases the filename part only, I like the new style as it is.
I don't like the idea of cyclic F2.
Posted: 20 Apr 2007, 17:57
by Guest
Anonymous wrote:I would be very happy to have "the option in the configuration to bring back old behavior."
Agreed. At least, have a configuration option to allow the old behavior.
