Wow, the help file is very nice! Thank you!
Request:
Is it possible to include a menu item that would allow me to"zoom" the help? Maybe the ability to change the fontsize up or down in increments is what I need (the help text is very small on my screen).
Or am I missing something?
RC2 Congratulations! and Request
The help engine is standard MS (HTML help) - so wouldn't it be better to send this request to Microsoft?JohnFredC wrote: My request for font size directly from help still stands, though!
What about other programs? Haven't you same problem with other sw, using HTML help (nearly all sw under MS windows)?
You're may be right, but my (perhaps mistaken) understanding of HTML help has been that the developer can control what appears in the menus. I haven't built HTML help myself, though.
Was scanning the new Salamander Help only out of curiosity and as a courtesy to the developers who spent so much time on it. They did a very good job.
Mouse-centric, Registered
I'm not 100% sure, but I know only "bad" ways to increase/decrease font.JohnFredC wrote:... can control what appears in the menus. ...
- use hack (bookmarklet javascript:void(document.body.style.zoom='150%') and not sure if it would work if associated with jump toolbar button
- start HTML help (when F1 pressed in Salamander) with another font (same font but another size) without possibility to increase/decrease after help started
- may be some ActiveX???
Menu items with font size exists in old WinHelp help (.hlp) not in HTML help (.chm)
