Possible to Hotkey Winkey+E ??
MushyWaffle
So first, I'm loving Salamander. However, I am a heavy keyboard user and love my shortcuts. I am always just popping Winkey+E for file access. I know this is native MS Windows command, but is there a way to have it launch Salamander instead of MS Explorer? Having to manually launch S from an icon is just too painful for me.
Re: Possible to Hotkey Winkey+E ??
Do you know you can assign your own hot key to Altap Salamander (or any other) shortcut? We are starting it this way.
I prefere to use CTRL+ALT+S for Salamander and leave the WinKey+E as is.
MushyWaffle
I understand, but I want the Win+E.. because that is the command that brings up File Explorer natively on 250 workstations I have. So I try to maintain habits and lack of customization, so I can move easily between them. I have customized heavily in the past and all it did was make me frustrated other machines didn't do the same. So I stick with the default commands.
To first responder (sorry, once I hite replay it doesn't let me see original)... No I didn't, which is why I was asking. SO, are you saying I can use the Win+E then?
You can not freely change default windows shortcuts...
some info is here https://answers.microsoft.com/en-us/win ... b896e80c3f
THe only "workarround" is autohotkey. But IMO thats messy.
