I have wrote a little AutoIt script which
wrotes the current WorkingDir (that's where SALAMAND.exe and SalaPortable.exe is in)
into a environment variable 'SalaPath'
and starts then SALAMAND.exe.
Unter 'user menu' i have edited my paths e.g. from
H:\Tools\Servant Salamander 2.5 beta 11\Plugins\CSDiff\CSDiff.exe
to
$[SalaPath]\Plugins\CSDiff\CSDiff.exe
So i can start Sala from an USB-Stick and have my path kindly relative.
Too bad i must import the registry settings... i have to take care of the settings on the foreign PC.
(Can't await the salamand.INI
If you want you can use the compiled exe or the AutoIt script on your own risk.
It's 'OpenSource' For an copy see the link below....
If you have 'suggestion for improvement', comments or questions
or want more info's please take a look >on my side 'SalaPortable' at DonationCoder.com<
