Buying a Microsoft code-signing certificate from Thawte?
Don’t use Vista.
http://www.itwriting.com/blog/597-buyin ... vista.html
We are trying to reissue ALTAP certificate just now... :evil:
dpokluda
Post by dpokluda »
I don't think I get this. I read the article (some unknown's guy blog rants) and I see that there are some issues with the signing process. How does it affect me as a Salamander user? Why should I stop using Windows Vista as you suggested?
David.
The post itself is a reply to the question in the subject:
Q: Buying a Microsoft code-signing certificate from Thawte?
A: Don’t use Vista.
It means you shouldn't use Vista for generating code signing certificate from Thawte, because you cannot back the certificate up or transfer it to another computer :(
dpokluda
Post by dpokluda »
Oh, I see. Now it does make sense. Thank you for the reply.
David.
