Two questions:
1) is it possible to capture the results of a search (Find, ALT+F7) in a list that can be pasted into a document, if so how?
2) is there a way to use the current Find in a grep-like manner - I want to see the contents of the lines as they are found (assuming a search in text files)
or, is there a plugin to provide grep-like functionality? I'm not interested in reg-ex, just the basic stuff described above?
Thanks,
poo
List of search results
Re: List of search results
See File list export from Find Files & Directories.boo wrote:1) is it possible to capture the results of a search (Find, ALT+F7) in a list that can be pasted into a document, if so how?
boo
cincura.net
boo
Yes, I know. But that requires opening every file in a viewer. I was hoping for a grep-like solution which gives an overview at a glance without the need of opening files. Thanks anyway. Hey, can you guys consider this as a feature requestcincura.net wrote: Not exactly. But in list of files (the result) just pres F3 and again F3. It opens file in viewer and finds first match.
