Please add an option to drop elevation when launching a program from an elevated AS. The following procedure works fine for our own tool, too:
http://mdb-blog.blogspot.co.at/2013/01/ ... m-uac.html
Drop elevation when launching a program
Re: Drop elevation when launching a program
Would be nice, but once UAC/LUA support is implemented, the usefulness of the feature would be pretty low. You can always put an application that can do it into your User Menu. For example, see Hidden Start and its parameter /nonelevated.
