While the Roadmap for Salamander 3.* looks promising, especially with the long-awaited Unicode support, there are other useful features that could be added.
It just does not feel right that Total Commander has most of those features, and Altap Salamander does not
For me that mostly concerns plugin viewers:
MMViewer - there are many types of files not supported now: *.m4a, *.mov, *.mp4. *.avi, *.wmv, *.mpg etc. At least some of them are covered by Audio Tag for Total Commander (flac, ogg, m4a, m4r, ape).
IEViewer - mostly works OK, but when opening some files, especially *.mht with a lot of pictures and/or scripts, it gives just too many error boxes that has to be closed manually. Also, some *.xml could not opened telling about unrecognizable format.
Eroiica Viewer - now, that's the most useful plugin - and still the most troublesome! Even older *.doc and *.pdf files are shown with errors, and there is no support neither for *.docx/*.xlsx nor for the 64-bit version. And viewing some *xps just crashes Salamander as I have already reported. As I have understand, the developers are not even sure if a 64-bit version is actually possible, although it is on the roadmap. Maybe it would be easier to replace it completely? If Oracle Outside In is too expensive, maybe there are other options? For example, I am now using sLister plugin based on SumatraPDF - works great with *.pdf, *.xps and *djvu! Any way to make it a native plugin and include it with future Altap Salamader versions? SumatraPDF is free, as far as I know.
Some other file types I wish to have a viewer for are fonts (*.ttf, *.otf, *.fon) - there is a plugin for Total Commander that works just great through TCProxy, and *.lnk (there is a plugin as well, but it does not work for me)
Well, I hope at least some of it could actually be realized!
A couple of more wishes concerning the available native plugins:
PictView - again, one of the best and most useful plugins, thanks! I could think only of *.svg format not supported by this viewer - maybe it would be possible to add it?
CheckVer - a little one, and seldom used as this Forum has more fresh information However, this plugin somehow shows version 2.54 as 'old or installed modules', while I only have 3.01 for now...
FileComp - well, I have only recently discovered that there is such a nice plugin bundled with Salamader (as well as DiskCopy!), and I was using extra software for quite some time already Compared to WinMerge I was using before, there is one useful little feature missing - an ability to select one or more line of difference and copy it to another file being compared - that is, making it not only differencing but merging tool as well.
Jan Rysavy, I think that's different problem - McLion had 3.0 installed and the plugin did not show 3.01 as already available for him.
I have 3.01 installed, so no new modules are detected (which is correct), but the plugin still says I have 2.54 installed (which is incorrect).
Btw, you should post one suggestion per report, see description on http://forum.altap.cz/ - we wouldn't talk about CheckVer problems in Viewers Improvements thread now.
