Hello, I see this error message for years, any chance to implement it? Doubt it's technically difficult
Copy Error
Unpacking to archives or plugin file-systems is not supported yet.
[OK]
- crystalidea
Re: Unpacking to archives or plugin file-systems
Actually, it's not that simple, if it's to be done right. If done simply, the user interface and performace could be bad.
Implementation of this feature would be very difficult.
- crystalidea
Ok, yes is hard if not just to extract to temp folder and move to destination.
Any plans on implementing this correctly?
