In the detailed view of the Windows Explorer you can filter files on name, date, type and size.
I grew to like this feature so much that I start to miss it in my favoriete tool. Is there any chance that it will be added to an update soon?
Filter files as in Explorer detailed view
Re: Filter files as in Explorer detailed view
I'm not sure what feature do you mean, could you show us screenshot?
It is in Dutch and I have a filter applied on the date column (EarlierThisWeek). Unfortunally I was not able to create of screenshot of the pulldown menu, but please let me know if it is not clear yet.
- 870 Altap Salamander.png (91.17 KiB) Viewed 6437 times
Filtering by names and types is implemented using filemasks (menu item Left/Right > Filter...).
For quick "filtering" by date and size, I recommend using sorting (menu item Left/Right > Sort By).
A very detailed filter is also available in the Find function (menu item Commands > Find Files and Directories...).
I have attached a screenshot of the pulldown menu.
- The pulldown menu.
- Clipbrd1.png (10.45 KiB) Viewed 6379 times
Oh, I see, that's Windows Explorer (in Win7).> A very detailed filter is also available in the Find function
That's where, Salamander?
Can't say that I've ever looked at or seen that before.
(And now that I look at it, I think, how ridiculous. Who knows, perhaps some use that instead of a real File Manager. And look, Size All Columns to Fit. Well I'll be. An actual enhancement.)
