when deleting many dirs (especially from temp folders, often more than hundreds), I want to have a point to say "All" (on not empty folders)
Delete-Dialog:
The directory ... is not empty.
Do you want to delete it?
Options:
Yes - No - YES TO ALL - Cancel
Thanx.
Deleting directories
Regards, Axel
Re: Deleting directories
Interesting, I've never noticed that. +1 for that.
At the moment, I can only recommend disabling the confirmation dialog completely (Options > Configuration... > Confirmations).
