Salamander allows you to copy the path, filename, unc, etc of the focused file in the Find dialog. If more than one file is selected, those copy-to-clipboard features are disabled. I'd like to be able to copy all selected files' path/filename/etc to clipboard.
Alternatively, if there is a feature to export the list of found files to an external text file, that would work as well.
Is there a way to do either or both of these things?
Thanks,
Daryl
Find Dialog: Copy ALL selected Files' Path + Filename
Re: Find Dialog: Copy ALL selected Files' Path + Filename
This command is not implemented yet.
Some workaround: http://forum.altap.cz/viewtopic.php?t=2758
I will move this thread to Feature requests section.
Hi Jan,
Thank you for your reply and for moving this thread to the Feature Requests section.
Regards,
Daryl
Regards,
Daryl
