I would very much like facility to be able to create a report on completion of a duplicate file scan.
Maybe export file details to CSV or XML file.
Thank you.
Azrael
Duplicate file reporting
Re: Duplicate file reporting
In the meantime, you can try using the User Menu to get some kind of report. Try looking at this Make List command.
Very clever - thank you.
