task manager in toolbar
Posted: 01 Jul 2013, 01:19
It would be nice if the task manager is also in the toolbar option
When you right click on the toolbar you get a list of Window components to turn on and off. On top of the list is "Top Toolbar". Two items below is "User Menu Bar". Those two are distinct items. For the Top Toolbar you can only choose from the options Salamander provides to you. On the User Menu Bar you can place any program or document you like.superBK wrote:The top tool bar is the user menu,
Applies to bothsuperBK wrote:just like what ether said i was referring to the toolbar having the icon option.
May apply to both, depending on your configuration. But to be honest, I didn't know those options were available on the Top Toolbar. I never use any toolbars except for the User Menu Bar.superBK wrote:It has the open desktop icon, control panel icon etc.
