Missing features
Kris
Re: Missing features
Post by Kris »
Hi Ino,
Brilliant, you are the best, my eyes are no longer bleeding :D :D :D :D :D
Cheers,
Kris
Kris
Post by Kris »
ino wrote:
Kris wrote: I want the focus on the command line and then it should scroll through the history.
just note: do you know that you can roll out any drop down list by using ALT+Down? It is default behaviour of the operating system gui.
Hi Ino,
Sorry but I do not quite understand what you mean by that, sorry !
If you could re-explain I would appreciate it!!
Cheers,
Kris
ino
Post by ino »
Hi Ino,
Cheers,
Kris
I meant that once you reach the Command Line by CTRL+TAB you can scroll items in the command history by CTRL+ARROW UP/DOWN and/or you can open the list of command history by ALT+ARROW DOWN and then navigate siply by arrows UP/DOWN.
Kris
Post by Kris »
Hi Ino,
Thank you for taking the time!
Yeah I am aware of this, I was just asking if it was possible to avoid having to gain focus on the command line first as you would not have to with many other NC clones.
Cheers,
Kris
