Edit: Allready solved -> ALT+F12 was what i looked for.
How can i access the "Directory Line" by hot key ?
I didn't have found them.
If there none, how about ALT+ArrowDown ?
(maybe press [Pos1] first if necessary if i have overseen smtg)
Or maybe "F4" like in iE ?
Access "Directory Line" by hot key
Re: Access "Directory Line" by hot key
Carefully, F4 starts editorStefan wrote:Or maybe "F4" like in iE ?
If you mean command line try this: Ctrl+TabStefan wrote:How can i access the "Directory Line" by hot key ?
or you can use menu - Help - Keyboard Shortcuts that will navigate you on this page: http://www.altap.cz/salam_en/features/k ... ml#cmdline
This post was reedited.
